Lee_in_KC said:If you're trying to avoid doing flares (and I can understand why you would... what a PITA!), NAPA and probably other parts houses sell various lengths of hard line with fittings pre-installed. You may have to add some extra jogs in some lines to get them to fit, but most of the hard lines will be out of sight anyway.
i ordered a 25' roll and had some left over but i did have some waste trying to get the flares right.what worked best for me was to mount the flare tool in the bench vise so i could make sure the ends of the tubing was nice and square then i debured the ends realy well and took small strips of 150 grit sand paper to champher the edges and that seemed to work realy well.Youngn said:it sounds lke i should buy more then i need to practice first before i make a piece two short.![]()
Youngster said:Make the longer lines first. That way if you screw one up, you can use it for a shorter line.
If your using SS lines a single flare will work. Use WD-40 when making your flares. Don't be afraid of doing flares, not hard to do. It's one of those things like sharpening drill bits, practice, practice, practice.
If you master cylinder is lower than your wheel cylinders, use a 2 psi residual valve for disc brakes and a 10spi for drums. This will keep the brake fluid from draining back into the master from the wheel cylinders.
