Youngster said:I have done some research on the bushed end on the hair pins. Although there are several cars out there on the street with this setup on them, I have found that the use of heim ends significantly increases the articulation of the hairpin at the ends of the travel arch. This upgrade should not be a problem as there are heims available from Speedway and others that can be easily be substituted for the bushed ends.
andy67g said:Well i just went to the free down load and good old pay pal came on and tried to charge for the so called free frame plan is not free I guess I had better start charging for showing how they did the inside measurements for the TR-2. The Big Kiwi says he is getting in line too get paid for turning you guys on to this. Boring !!!!
does anyone have the measurements for a T bucket frame ? I bought all the metal today and im not sure exactly how long and wide to make it ? 107 long, 30 wide in the rear and 24 wide in the front ?
went to save file and could not locate the plans, what do I type in to search for your plans on savefile ?
Yes it is, but it works.Isn't that the link from post #8, above?![]()
Oh no problem at all.Sorry, Ron. My inner smartass decided to come out and play. It wasn't meant as a slap at you.![]()
