Royal Purple was my plan, except for the 500 mile break in, where I was going to use the regular oil with the ZDDP additive.
@Dave, The reason I'm going with the rack and pinion steering is to help prevent bump steer. Every condition you listed is present no matter what kind of steering set up is used. I listen to all comments and may change my mind accordingly, but it's to late in this case. I already paid over $300 for the rack and pinion so I will be using it. If I find it has too many bad side effects I'll change it a little ways down he road. Thanks anyway.
@fletcherson, I realize the importance of a piston fitting the bore of the cylinder. It's all about tolerance. The tolerance of the bore is (I think) +.0025/ -.0003. I could look in the book but I think that's the bore tolerance. The piston is also made with a tolerance, that fits inside the bore tolerance. The piston will probably need to be deburred but, when everything is "in tolerance" it all fits together correctly. It would be a good comedy to watch a engine assembly line if they were test fitting each piston to each cylinder, lol. They wouldn't get many engines built. Please don't be upset with me, as I have heard this from other people as well, so it is a common belief. After 30 years of machining and making auto parts by the thousands, I learned that a part that is in tolerance (and looks good) will fit in its mating part, as long as that mating part is in tolerance. (The looks good part is simply for the buyers satisfaction.) I do agree with you on the oil for the camshaft, containing enough Zinc, or ZDDP.
