ChestersAlive
There are a lot of good frame plans out there. The frame is the backbone of your roadster, everything directly or indirectly attaches to it. It is NOT a place to learn how to weld. It should be built by a competent, professsional welder who knows what rod to use, heat range, weld penetration etc. Learn on the brackets etc.It should be built in a jig or possibly on a perfect flat floor.You're better off buying a pre-assembled frame from a well-known company and be safe. Anyone can grind off the chickens--t and make it look good but how good is their penetration? Did they use the right rod or something they found in a yard sale? 80 MPH on a freeway between two semis is no place to find out the man who built your frame is a shoe-salesman who welds in his garage with a $100 mig-welder at night for a little extra money.
In buying a frame ask the company if they use 1 1/2" X 3" tubing or 2" X 3" tubing. Look close at the roadsters you see in a meet and decide which you'd rather have. A 1 1/2"er gives my the willys just to look at it. ChestersAlive
