rubicon
After driving for about ten minutes at 45mph the front and rear calipers get hot. I pulled into the garage, put car in neutral and was unable to push the car forward or reverse. Jacked it up and the front wheels would not move. Back wheels moved but hard. After about 10 minutes the front wheels were free.
I have disc all around. (Wilwood) The other day when I check the temp only the left rear was hot and both fronts were around 98 degrees. I re-shimmed the left rear to make sure it was centered. I also adjusted the proportioning valve. Decreasing the line pressure to the rear which allows the front to do most of the work when braking. My MC with booster is under the floor. I also have a remote reservoir for the brake fluid on the firewall. What could be causing this and what should I do first?
