Looks like I would check fuel level in the bowl.[ Float adjustment]
Yes that is controlled by the float which needs to be checkedCould it be the niddle is stuck open?
They should make the bowls clean. hehe
Just as a off note;
A little trick that helps if you do hard stops and starts or fast corners is to add a hose to the float top tubes to get them up higher near that top of aircleaner,it keeps fuel splash from coming up and out as EZ=motor stumbule right after hard start or stop or fast turn.
He's talking about the center vent you have circled on the pic of your carb. This tube used to be taller and a pressed in brass tube. Under extreme g's fuel could walk up the tube and spill over into the carb, ususally stalling it or causing it to break up. A simple cure was to slide a short piece of gas hose over the vent making it taller. Some carbs had this tube on both ends and they would connect the two with gas line and cut a skit vent in the top of the arc.????
