CHANGING STEERING WHEEL ANGLE
Todd Honeycutt
As the title says I need to lower the steering wheel on my bucket. It appears to be a piece of flat metal mounted to the firewall then clamped to the steering column. Do they make these in different sizes or can I modify the one I have?
Make sure if you change the angle at the top you don't bind the joint at the bottom if you have one
