fluidfloyd
This is for those of you that are building cars that use coil springs or coilover shocks. If you buy a kit it will usually come with the correct spring rates as decided by the manufacturer. But if you are building on your own then things can sometimes get confusing. When choosing springs there are a number of factors to consider and at time it just cause your brain to hurt. I am at that point as I speak and since I'm working through this I thought I would post these two links that can be of great help. You can sit down with a hand calculator and run the numbers or you can use these online problem solvers. The first site will be of great help in determining the spring rates that you might already have on hand.
http://www.pontiacracing.net/js_coil_spring_rate.htm
This second site will help you in shock/spring placement.
http://www.proshocks.com/calcs/index.htm
You still need to use common sense in mounting things but these two tools will be of valuable assistance to some. One other point. If you are doing a custom design and you need technical help from the spring source, always call and ask for someone in engineering. Sales people usually can't give you wire diameter, number of coils or anything not shown in their catalog. I hope these will help you at some point.
George
George
