just for fun
For the first 10+ years of my T's life all was well. Streets of Tucson were smooth and straight.Then we moved to Valdosta, Georgia. The honeymoon is over. Running a Corviar box on top of the frame. Can't get the slop out of the box! Approx one inch of free play at the wheel. This causes the front to hunt the road when it encounters those unseen ruts made by max loaded Semi's. Starts out as both tires going right-left togeather and if no correction action is taken the ark that the front tires are going in becomes larger! Most of the time I can catch it when it first starts. Moving the car out of these "Ruts" and at the same time letting all the way off the gas-shifting more weight to the front will stop it. Once it get started the only way to stop it is to stop the car!! This is a no shocks front end car that worked till I got here, and still works on good roads. Oh, everything in the front end has been checked for wear. has enyone run into these? Maybe a short shock from the pitman arm to the frame like the 4 wheelers run?
