bluefishNZ
Hey there all you experienced Tbucketers ....
I have a question about glassing the body interior.
I have just put in a new floor and "wooded" the interior.
I used 18mm marine plywood and used some super dupa liquid nails to
glue everything in place.
I did a test on the adhesion properties of the wood / glue/ fiberglass before I went crazy.
I used about thumb nail sized dab of glue and then clamped a piece of plywood, I left it a couple of days (7days is the full strength cure)
I could not pull the wood off, I had to get a big chisel to pry it off the glass, and then it pulled the glass off, there were strands stuck in the glue.
So I think the adhesion should be plenty strong enough.
So as you can see from the picture there are a lot of ribs (top rails double layered) and a lot of surface area glued.
the body feels super strong and there no flex,
So is there any need to glass over the ribs.
would love opinions for / against this ideas.
the full process is documented on my website
