ask away, there isnt much I dont know about the chrysler hemi nowdays.
to clear up a few misnomers:
1. you can get the weight of a hemi down to about a BBC. It takes some money and allot of cast aluminum.
2. it is cheaper to build a SBC then a hemi....but then your stuck with a SBC. It really isnt that bad. Pistons can be had for pretty cheap unless you want that custom set like I had made. I would say its about 1 1/2 times more expensive.
3. Chryslers are better to build because there are many more parts and speed parts out there. A desoto has nearly no speed parts and the ones that do pop up cost more then most motors with the dodge being only slightly better.
4. 392s are acutally cheaper then a 331 or 354 because of the part on the market. But if you know allot or read allot you will learn that you can mod a chevy distributor to fit, chevy water pumps will save 40 pounds, use small block dodge starters etc.
4. Bob Walker is one of the most knowledgable and will answer any question you have. He is super busy but if they can get him to the phone he can answer any question you would have. Also Pat at Wilcap has the whole tranny adapter thing down to simple packages.
5. I have a copy of an article by Gene Adams somewhere. The hot setup according to him and my dad (who built funny car motors through the 70s) is a 392 block with 1955 331ci heads. These are the best heads having the best volumetric efficency and flow plus a little higher compression. Plus the bore and stroke of the 392.
mine is a 1955 Chrysler 331 with the good heads punched to 346 with tons of head work.
kisses,
Chop
kisses,
Chop
