Welcome to Our Community
Sign Up
Dismiss Notice
door hinges
Discussion in 'T-Bucket Body Articles' started by Old Guy 65, Oct 11, 2017.
  1. Old Guy 65
    Old Guy 65
    Expand Collapse
    Aug 3, 2017
    10
    1
    Gender:
    Male
    What is everyone using for door hinges. The only ones I can find are way too thick. I only have about a 1/4 inch around the door. I need some thing thin. How about door latches?
  2. Indycars
    Indycars
    Expand Collapse
    Mar 11, 2010
    2,502
    1,109
    Gender:
    Male
    I recessed the hinge and latch. I'm using a original pieces.
  3. old round fart
    old round fart
    Expand Collapse
    Feb 5, 2008
    3,214
    1,182
    Gender:
    Male
    Occupation:
    Retired
    I can’t believe I didn’t notice you had a door as many times I’ve seen it!
  4. Indycars
    Indycars
    Expand Collapse
    Mar 11, 2010
    2,502
    1,109
    Gender:
    Male
    Yea, it's been there since 1980!
  5. hulkamania
    hulkamania
    Expand Collapse
    Sponsor
    Forum Sponsor
    Mar 6, 2008
    596
    136
    Gender:
    Male
    Occupation:
    Sales Manager
    Here is the door hinges that we have specially made for us. Also we use a bear jaw latch inside our door
  6. butch27
    butch27
    Expand Collapse
    Nov 5, 2007
    2,493
    188
    Gender:
    Male
    Occupation:
    Retired
    Wouldn't Those have to spaced out at the bottom like Originals??
  7. brsturges
    brsturges
    Expand Collapse
    Aug 31, 2016
    37
    6
    Gender:
    Male
    Do you guys sell just those hinges by any chance?
  8. hulkamania
    hulkamania
    Expand Collapse
    Sponsor
    Forum Sponsor
    Mar 6, 2008
    596
    136
    Gender:
    Male
    Occupation:
    Sales Manager
    yes we do. They are $50 for the pair
  9. Old Guy 65
    Old Guy 65
    Expand Collapse
    Aug 3, 2017
    10
    1
    Gender:
    Male
    Does the door have to swing up ? Can it just open straight?
  10. hulkamania
    hulkamania
    Expand Collapse
    Sponsor
    Forum Sponsor
    Mar 6, 2008
    596
    136
    Gender:
    Male
    Occupation:
    Sales Manager
    they open straight. The key it to make sure you hinges are parallel to each other or they will either swing down or up.
  11. tdkkart
    tdkkart
    Expand Collapse
    Dec 3, 2015
    53
    26
    Gender:
    Male
    If you're on Facebook, Spirit has several videos on their page covering hinge installation so that the door will open straight.
    The key is to get the hinge pins in line with each other and perpendicular or 90* to the ground.
    The slickest way I have seen using this style hinge is to knock the pins out, then use a long piece of 1/4" threaded rod or all-thread through the pin holes and some nuts to hold the spacing between the hinges. Install the hinges so the rod ends up 90* to the ground, leaving the hinges on the threaded rod until they are fastened in place. Remove the rod when the install is done and your door will swing level with the ground.
    Guy and Spanky like this.
  12. Neshkoro
    Neshkoro
    Expand Collapse
    Jun 29, 2009
    1,488
    746
    Gender:
    Male
    Occupation:
    Retired
    Great simple idea!!!
  13. butch27
    butch27
    Expand Collapse
    Nov 5, 2007
    2,493
    188
    Gender:
    Male
    Occupation:
    Retired
    It's hard to knock out the original pins.
  14. DonnyRay
    DonnyRay
    Expand Collapse
    Oct 20, 2017
    1,804
    1,310
    Gender:
    Male
    Occupation:
    retired.
    I also have the original hinges. Thanks for the 90 degree tip for placing the hinges.
Share This Page
SSL Certificate
