Does any one have any photos of a dropped radiator mounting? I am using a 32 grill shell and without dropping the mounting 3 1/2 inches the radiator tabs are too low to use the mounts straight across on the frame. I am thinking about lowering the mounting tabs on the frame aprox. 2 1/2 to 3 inches below the frame and run a piece of 1/4 x 3 flat bar across them to allow the allow the body cowl to line up with the top of the grill shell. I have access to a little plate slightly smaller than 3/16 to make the new brackets with. do you think it is thick enough or should I use 3/16?
