roadmonster
Here's a very simple toe-in jig that really works. Just frame up a long U from center to center of your tires with short legs the height of your spindles. One side has a thin blade which rests against the tread block and the other has an adjustable steel ruler. That's it. Start at the rear and adjust the ruler to an even number. Now move to the front and tweak the tie rod for the desired toe-in. The rear will move a little as well, so re-center the ruler after adjusting. Now go back to the front for the true toe-in. This thing is very accurate!
