Ok, I'm back in the house after a little more shop work.
2 Old 2 Fast suggested that I install power valve check ball kits in the carburetors to prevent power valve blow-outs. I thought this was a great idea , so I did. I also thought I would share my experience with those of you who have not done this and would like to. (This is my first time as well). Those of you that have, please bear with me. Also it gave me a great opportunity to clean some of the clutter off the Bridgeport mill and utilize it. I fine a Bridgeport can be in many ways just like piece of exercise equipment. A Bridgeport collects clutter like a a treadmill collects clothes. LOL By the way a drill press will work fine as well but I have a Bridgeport so why not use it.
Step 1. secure and stage your work to the table.
Step 2. Align the chuck over the hole to be altered. I did this by using a drill the same size as the hole (installed upside-down in the chuck.
Step 3. Once aligned use the drill provided in the kit and drill down .300" from the drill point (from a drill point touch).
Step 4. Blow chips away and stage component to be installed. I found the instructions to be unclear at this point. The instructions say to install the spring with "tapered side facing up". I think it should say with "small diameter of spring up" (It could just be me). I have tried to illustrate this pictorially.
Step 5. Install spring with small diameter up in the drilled hole followed bu the ball.
Step 6. Stage the seat directly over the hole. Note: I think the seat should be installed with die roll up (Burr up).
Step 7. Using a pin equal to or larger than the diameter of the seat to press the seat in flush to the housing. I did this using the drill chuck.
Step 8. completed assembly. Check to make sure the ball moves freely and the spring re-seats it and in my case repeat steps as I have two carburetors.
Oh and the burr on the top came with the seat. I didn't create it...Thanks Speedway Motors. Hence why die roll up.
P.S. If you don't have power vales on the secondary side you don't need two kits for two carbs. Wish I had known that. Live and learn.
Now to finish cleaning the rest of the undesirables off the housing and hopefully I can start the re-assembling this weekend.
Until nest post, Mike
