In my not-so-humble opinion, the Joe Gibbs BR oil is your best bet. Assuming you have built the engine with standard bearing clearances, the BR-30 is a good choice.Well, then, what oil should I use for the first time start and break in of the cam?
Only if you're running wide clearances. If not, the conventional HR-2 10W-30 will be just fine. There's really no reason to run higher viscosity oils, unless you have some wide bearing clearances or you have an air-cooled application.The 15W-50 Conventional?
In my not-so-humble opinion, the Joe Gibbs BR oil is your best bet. Assuming you have built the engine with standard bearing clearances, the BR-30 is a good choice.[/aquote]
Do you know if I have to order this online or is it available in auto parts stores?
Thanks
Thanks
You'll have to look around, to see if you have a local distributor. It's available from Gibbs, if all else fails.That is a good question, where can one find it? (Joe Gibbs Driven Hot Rod oil) and what is the cost?
Dry startups are, without a doubt, some of the toughest moments any engine will ever go through. But actually, the most aggressive wear is those first 15-20 minutes with fresh rings, fresh bearings, fresh camshaft and fresh lifters. Which is why oil changes are recommended within the first few miles of running on a new engine.However, unless we've all been duped by the ZDDP additive makers, we do need to account for the need for some help if running the cheapest oil on the shelf in your older engine. The makers of STP claim that their product has enough ZDDP to do the job, and of course it also has that clinging ability that lasts for months. Since the most wear an engine sees in normal use is at startup after sitting for a while, I contend that STP makes good sense in this case.
I just ordered a case of Joe Gibbs HR 10w-30 from Amazon. com for $96.00 with free shipping. Best price I could find on the net.
Is that a 24 case? or half a case? 12 I know there used to always be, 24 in a case...???
<br> <br>It helps with the lubrication. Adding trans fluid is about the same as adding some Riselone to your oil. Keeps things clean and lubed, also keeps seals from getting hard! Also keeps varnish from forming.<div><br><br><br>This is a very good question, as I am at that crossroad right now myself, I always ad a quart of ATF to every oil change, but don't really know if that helps with the tappet/cam problem..??<br>
And the black art of oils continues... I've always heard/read that thicker oils will pound out easier than thinner oils, because the molecules tend to cling to each other rather than the metal when extreme forces are exherted upon them. Even so, I've always run 20-50 in older engines with no issues at all. I've also read that while 10-30 and 20-50 are fine, 10-40 is very bad stuff, due to some formulation issue that escapes me right now. Some people love synthetics, some hate them. I like STP and typical 10-30 or 20-50 with STP, but some hate STP. (I must admit to not liking to work on an engine that runs it because it leaves such a sticky / slick surface that is hard to wash off.) Some people seem to like running some ATF in their engine oil, which seems really odd to me! My point is, whatever you run, someone is going to hate it, and have a "better" solution, and admittedly, they may be right for their particular case.
What I DO know is that I have over 25 engines here that I regularly change oils in, and it gets really expensive when you add it up. Therefore, I use what's recomended by the majority of the manufacturers, and believe I don't need to buy super expensive stuff for these engines to survive, and this has proven to be true. I DO run synthetic in the new 'Vette and the Lexus, but other than that I run all conventional oil, and anything with more than 75K or so gets a hit of STP as well. The tractors all run Delo, 'cause it's cheap and has worked very well in them.
When I built the '65 Jag. Mark II about 30 years ago (put a small block Chebbie in it), the used engine had about 140k on it at the time. It now has over 300k on it, never been apart, doesn't use oil or have any bad noises, but does leak a little out the front seal. I've run 10-30 and STP in the winters months, and 20-40 with STP in the summer months all that time with no issues. When I stick my little pinky in the drain hole to check for sludge, I get NONE. What I'm doing just can't be all bad... Notice I didn't mention oil brand? That's because I buy whatever name brand is the cheapest, which lately is usually Chevron. The most important thing with oil is to change it regularly (I do so at 3k miles). One thing I do is to ALWAYS change the filter when changing the oil.
Now for the horror story. I bought a '99 Chevy Astro van a few years back with about 80k on it. The oil looked terrible, but the price of the van was cheap so I bought it. In a fit of lunacy, I decided to clean some of the crud out of the engine when I changed the oil, and added a bottle of Marvel Mystery Oil (on the recommndation of a friend.) I ran the engine for about 10 minutes at idle to warm it up good before draining the oil, and by the time I was ready to drain it, it was knocking. Upon tear down, I found a bad main and two bad rod inserts, and a scored crank. I won't be using Marvel Mystery Oil in the future. (Come to think of it, that stuff looks a lot like ATF! I wonder...) I know that the real problem was a lack of maintenece prior to my buying it, but you just can't wash away many miles of neglect with Marvel Mystery Oil.
Just my experiences...
CB
PS For you Red Line and Amsoil guys, did you know that they don't even submit their oils for API certification? Read it on the internet, so it's got to be true!
----What I DO know is that I have over 25 engines here that I regularly change oils in, and it gets really expensive when you add it up.----
Thats the reason why I run all my used oil thru a oil scrubbing system, then pour it into the tank of my diesel truck! Helps kick my fuel milage up and lubricates my IP and injectors.....
I run 20W-50 in most cars, 10W30 in lawnmowers and motorcycles, most racing stuff, 20w50/50 racing oils, 15w40/15w50 in the diesels.
if its old and needs slack taken up some....use STP. Wanna make it live thru rough treatment, use Lucas Engine oil stabalizer. Additive for heat? STP or Lucas oil stabalizer
Stay away from the snake oils! The Amalite CD-2 really works for slowing oil past rings. (Old Farm Tractor!) Riselone is great for keeping the inside of your motor clean! Use it on a older motor....I guarantee the pump screen clogged inside of 10 to 15 minutes. A little diesel added to your oil is alot less aggressive! Uncle Sams research talking there!
The cleaners and medics, don't use them unless you know how to use them!
Synthetics are good for running long periods between changes on motors that have tight tolerances. I really like synth-blends! Synths in used motors with alot of wear is a no-no! Will leak past your seals and rings! New motors, full synths are fine. My own personal stuff, synth blends when available.
Oil can only do so much.....it lubricates and cools. It can't however, perform miracles. IE, you can't add it to you crankcase to plug a hole in the side of your block!
I have an 88 Bronco II and a 93 F150, 302, both have had diets of Castrol 20-50 year round since new, both have over 290,000 miles with no knocks or smoke. I like to think the thickness helps the oil stay in place longer between starts. Also Comp Cams and Amsoil are advertising Zddp oils for those in the know.
