2old2fast
I'm sitting here smiling ..why? In '09-10 I built a 388 sbc stroker [3.75x4.060] Ran great , didn't foul plugs , gobs of power BUT sucked oil to the tune of a quart every 250-300 miles...tried modifieying pcv , pulled the intake numerous times suspecting a intake gasket leak , replaced some valve guides [they were bad] basically tore my hair out , leakdown test showed a very tight ring seal , compression was 175 across the board. Finally , over he winter I pulled it down . When I assembled the motor , the rings [grant] didn't come w/specific instructions so I called them , I was told [Iwrote it down ] that the bevels go down on both 1st & 2nd rings....that's the way they went in . Called back & asked again , this time they said Top ring -bevel down 2nd ring -bevel up ..ARRRRGH.Well , I now have Mahle rings , installed as per thier instructions , have put 300 miles on it & haven't used a DROP of oil..tenacity pays
well , it now has Mahle rings in it
