Put a new power valve in the Holley carb (1850 600 cfm) . Really cleaned up the idle and off idle response. I knew it was bad, but was able to adjust over it, until I got to it.
AND the augers are installed. I had to grind down the augers just a little to fit in the pipes. I think it is still a little LOUD. I ordered 2 packs of stainless steel wool from Summit.
I really felt like I got something accomplished today. I pulled the steering wheel and sanded it, for a coat of paint. It is a grant wheel and has just seen too many days.
I just ordered a couple of Edelbrock heads for a 302. I am going to replace the engine in the purple beast. I think the engine I have is a flat tappet truck engine, less than 200 hp. I have 2 mustang gt engines both running when pulled. They are 225 hp roller cam engines. I hope to swap most of the external stuff over from the roadster to the new engine.
Here's a good one, the dip stick on the engine is in the rear side of the block. The pan is a front sump. They cut the stick off where it go in, but not touch any oil, since it is in the front sump of the engine. I bought a new dip stick and was going to drill the timing cover, but I was going to wait until an oil change and pull the pan at the same time.
I have 2 Edelbrock intakes, an Airgap and RPM that will replace the Weiand, ( say why and ).
Now to the transmission. I has a B M, sounds like some initials my grandparents used to use, ratchet shifter. On a side note I called B&M to buy a pin and clip, they only sell the shifter handle and shift light. Everything else you have to send the shifter back to them and they will rebuild it for you. I acquired a Ford floor shifter, which I think will be a lot eaiser to use. The trans seems to be a Cruis O Matic. If you are not familar, it has D1, D2 and L. I put the ratchet shifter in what I thought was 2 to have some pep while crusing at low speeds and felt the trans shift to 3rd. The Cruis O in the 2nd position D2 would start in second and shift to 3rd. This is a trans from the late 50's. Fortunately I have a C-4 I am going to take a chance on.
I promise to take some pics so you guys can relate to all the stuff I am talking about.
I appreciate all the help. Oh yeah I have a red interior with a purple car, I cannot figure that one out.
railroad
