rubicon
I have a CCR body and windshield frame with posts. I've screwed the post to the frame and now I'm ready to try and fit it to the body. The holes are already drilled into the body so I must grind off some of the body to get everything to line up. The body is a little wider than the windshield & post set up. I believe this is correct so far. Once I have everything lined up I then fill in the gap between the post and the body with Bondo and blend into the rest of the body. If what I have is correct, then what do I cover the inside of the post with to keep the Bondo from sticking and the post a permanent part of the body?
