Ford 302\C4 Trans Driveshaft
gfigms
I have a CCR frame and have a 302 with C4 trans mounted. Ford 9" Currie rear end. Now, the drive shaft ends up only 4" of actual 'tube' and 7" center to center from the U-joints .... is this going to be an issue?
Should not be a problem as long as you get your angles right. You will not be doing any off roading to get too much suspension travel.
