front shock mount
oino
I need some ideas for the lower front shock mount. Anyone have anything they've done that points front to rear?
I need a lower mount. To mount the shock to where the spring or something.
Sorry. Don't think I was making sence. Here is a pic. I need to some how mount the shock that way. :-)
Come straight forward with the bottom of the shock and weld on some small tabs to the axle.
I was thinking of doing that. But wasn't sure about the look. Was hoping for a few other options. Then pick one. :)
hmmmm
Here's how I did mine.The shackle is made from 1" dom 1/8" wall. bolt is a grade 8 milled with a 1" end mill and tig wilded to dom. Shock mount is made from 1 1/4" X 3/16" plate set at 60* to mount bolt. I have more info if you need it.
Terry
How about this. Made me some shock mounts today. Should work, right?
Just need to weld them on. :-)
Here is what I did, I did not want to put any more stress on the spring bolt so I made a mount and welded it to the batwing.
