Ackerman is the principle where the inside wheel turns at a tighter radius than the outer wheel. When you put the tie rod in front of the axle you've reversed the Ackerman and the tires "scrub" when making a turn. To correct this you need to modify or make new steering arms. To see correct Ackerman string a line between the center of the tie rod mounting bolt and the center of your kingpin on both sides and they should meet at the rear end. With a reversed Ackerman the two line will never meet as they will to infinity. Would you like to be in an emergency situation where you had to make a sudden turn to avoid an accident and the tires did not want to cooperate and merely skidded along instead of gripping the road and turning to avoid the possible collision? I know that I'd not be too happy in that situation.Jim, could you explain what you mean by that? Not questioning your post, just want to learn a little here.
Lee
Thanks Dale. I did a bit of searching, but not on da tube yet. Jim, just read your post also. Now I get what you mean. Never to old to learn.
Lee
3 months ago I had never heard of ackerman, but I probably have 10 hours of research, reading, and talking to people in the know, for every 1 hour I have working on my car. And a LOT of listening to you guys on here and reading about every post ever put on here. I'm a little bit of a book nerd, so reading about chassis engineering when I decided to build it from scratch myself, has been almost as much fun as the build. Jeddie I would recommend you calling Ron over at RPM (one of the sponsors here) and letting him look at your photos. he makes a weld-on batwing for the I-beam axles and he can integrate the spring mount with it, and I'm sure he could build you a set of steering arms to correct the alignment issues as well. Very reasonable prices.Thank you, Dale, for that sketch. I know that there are guys, for whatever reason, don't believe Ackerman is important but I figure that there are a whole lot of guys that are WHOLE lot smarter than me that have figured out the importance of this.
On the early Fords, 40's -50's I think, the tie rod was out front, some anyway. I remember having to straighten the tie rod back out after having hit a stumpI think the real trouble is using your tie rod as a front bumper.
It seems as though you have to join that sight to get any info. At one time you could get a lot of info there but not anymore.You might take a peek at this Ackerman explanation.
http://nationaltbucketalliance.com/bb/viewtopic.php?f=20&t=264
