Front tires
Kosterman
Hey Guys. This has probably been discussed before but after searching for an hour, I can’t find anything. Here’s my delima. I’m building my first T. I scored a set of 31x18.5x15 for the back. I gotta figure out something for the front. I don’t want narrow bicycle tires on the front, but obviously not something too wide with no power steering. I don’t want a major rake on the car, but some is fine. I was thinking maybe a 215/70/15 with a 7” wide wheel? I don’t know. What are you guys running? Any input or pictures would be greatly appreciated! 🍻
I'm running 185/60r-14's on my front. I like the larger footprint for braking and handling. A popular front tire on a lot of hot rods is the Michelin XZX radial. Been around for a long time and looks good on most cars.
Thanks! Yea that’s a good looking tire and your car has a nice stance. Are those 31s on the back?
The back tires are BFG Euro TA's 305/50-15. They're about 10" wide, and about 29.5 diameter. Sometimes my phone camera distorts things a bit.
Is that the tire or the wheel?
Can you tires for the front and rear that match tread design?
I am running Mickey Thompson Sportsman 26X7.50-15's on the front mounted on Crager S/S's. with about 15lbs. (Sorry, unable to upload photos)
A tire size is 3 things; width, aspect ratio and wheel diameter.
If you have wheels, that's set.
Then it's a certain amount of width for the wheel width.
Finally, how tall you want it to be within available tire sizes. The aspect is percentage of height to width.
You can try to match tires by brand and model but bigs and littles make that tough. At least use the same construction, radials OR bias ply not mixed.
