Fuel line ?
A 3/8 line is all you need for a fuel line.
If your planning on going to a blower later on then go to 1/2inch line.
Return line is going to depend on your pump and regulator..
For what you got.....a 5/16 would be plenty. Usually a 3/8 is for 850's on up in hi RPM applications...............1/2 is for the dominators or the old Crower or Hilborne systems at the pumps that drive directly off the cranks..........
It won't hurt anything to go bigger.....just isn't needed
Brucer is right.....now if a blower is in your future.................
If you are going bigger, remember to use all steel line, except for the short connections, in all reality, it is best to do this with any size fuel line, much less chance if failure along the way... Just always try and keep it away from HOT stuff... :lol:
Ted Brown said:
If you are going bigger, remember to use all steel line, except for the short connections, in all reality, it is best to do this with any size fuel line, much less chance if failure along the way... Just always try and keep it away from HOT stuff... :)
Yea......what he said!!!!!!!!!!:):lol::lol:
