engine24355
Okay guys, I have the new regulator installed, but not sure it is working properly. No mater what adjustments I make (all the way one way and the other plus everythign in between), I cannot get any pressure above about 4.5 lbs. Also, the gauge does not change much at all as I adjust the regulator. So, me thinks I need to try another regulator. Am I thinking wrong here or am I missing somthing? Just seems like I should be getting some different readings as I adjust.
Thanks!
Thanks!
