Wild Mango
Stick with it. The terminal voltage with the pump running should be within 5% of the battery terminal voltage with the pump running. However, if the connections to the pump are dodgy the pump won't be getting the juice, those Carter connections with the knurled studs are not the greatest for on and offing.
Restrictive line fittings will impede flow but they will not impede static pressure (pump pushing against a block). Are your initial pressure readings static? They must be to give you a base line. If the pump will not reach rated pressure against a static block, then;
1/ Input to the pump is severely restricted.
2/ Pump is not getting full electrical power.
3/ Pump is faulty.
4/ Pressure measurement is inaccurate.
Since you keep getting 4.5psi as a reading my nasty suspicious mind thinks 4/. This is the commonest one I see from customers.
As Claude Cessna said, extracating himself from another wreck, "I don't like these things right now but they will never beat me".
3/ Pump is faulty.
