is every one using a standard fuel tank for the 23 t bucket or is every one haveing to pre fab i plan on using a fuel cell from summit unless there is a better plan:razz::razz:
The tank from TP is the one I used in mine but I'm leaning toward a 49 Ford tank from bob Drake Reproductions http://www.bobdrake.com for my next one. It is 24 1/4 x 24 x 8 1/4, holds 17 gallons and will fit between the frame rails. I'm extending my rear frame to make a flat bed so I will have plenty of room,,,,,,,,,,,,,,
Oops. I forgot about RPM. He should be able to build whatever you want.
I am using a fuel cell, the main reason being, I already had it on hand. I think you will get a lot of different opinions on this. From the pictures I've seen, and comments if heard, you will not beat RPM Motorsports work and fair pricing.
I ordered a tank from RPM for my 23T Spirit build. He has everything already and makes a quality part! Ron is a great supporter and poster of this board, check him out!
