rooster57 said:The first thing i did was to make two 1 inch by 3 inch plates i think 1/8 thick and machined two slots in it to match the windshield stantion bolt pattern. one for each side and bolt them on the inside. Then i used 1/2 sq tubing and cut a length about 6 inches longer than the distance between the two plates one on the driver side and one on the passenger side. then i used my 1/2 conduit bender and put about a 3 inch offset bend in each end then cur to fit between plates. I think i cut it so it would wedge between the plates so i could tac it on to each plate. after tacing i removed the bolts and welded. Then i installed the column and attached a small bunge strap and set in the drivers area and measured the drop distance. Then i machined the drop and drilled and tapped the top of it 1/4 28. I cut a 4 inch by 1 1/4 inch also 1/8 plate and bolted the plate on top of the column drop offset to the rear ,installed the column made adjustments side to side clamped the plate to the sq tubing and removed the column and drop . Removed the 1/2 sq tubing that spanned the under dash area and welded the plate on and primed and painted. Email me if u need a pic i think i may have a couple if needed.
Tim
rooster57 said:I built my own harness i do a lot of this type stuff everyday so i have lots of wiring supplies around. Thanks for the compliment . I have got so many good ideas here i hope mine can help others with their projects.
rooster57 said:I sent u some pics Engine 24355
