fordsbyjay
This morning I performed the square and straight procedure posted on the NTBA here.My question is how perfect (or what kind of error) should one allow on your measurements? My car is not square but off approx. 1/8" each way or 1/4" total. I also measured the tire diameter via the markings to compare tire size and there is 1/16 difference on a couple of them. I have a set of toe plates that I used to set my toe in and with the plates my toe out is 1/8" but by the measurements on my sheet it is showing 1/4" so that is why I ask about the amount of acceptable error. Where the A-B lines cross it is 1/16" to the left of the vehicle center line.
If I understand the data I would say I have to shorten the front right and rear left by 1/8".
