Your roller, do you just back off on the top tube to remove your piece? What did you use for bearings in the tubes? What size are the tubes?
Your break press, are you using angle iron for the dies? Is the top die interchangable? Are you using an air nozzle for a valve?
Awesome work. Looks like I found a couple more projects for this summer.
Great progress I like the dash with the dip down in the middle.
Most guys would be delighted to be making this great a progress on their project but you are making FANTASTIC progress on TWO at the same time. I think that you should change your name to SUPERMAN!
I think I would have moved the complete rear end back about 6 to 8 inches, may have fit the longer bed better... But, that is just me... Lookin good.Note; If I back into something, I would rather hit the tires than the bed...
From the side it is dead on... If he back's into something with a t-bucket,, He needs his butt kicked..LOL
Looks like fun there is one thing I see might be old eyes but in the pic from the front it looks like a little to much positive camber.
