I usually run the same size for both. I also run a short ground from the battery to the frame and a ground from the motor to the frame. You can never have enough grounds IMHO. If you had a smaller ground cable I think you could 'supplement' the smaller ground cable by using the mentioned frame grounds. This way the frame and the ground cable would suffice. If starting from new just use the same size to begin with. I use OO welding cable for my grounds and power cables available per ft at your local welding supply store.
To answer you question, yes you can. Just make sure that you use a star washer at each connection to the frame to insure a good connection.Sorry for hijacking thread, but I am getting a lot of info here, too. Now, if I have my battery mounted behind the body, can I just run a ground to frame from battery, and a ground from starter to frame, without one long cable from battery to starter?
I hope I made that clear.
Thanks
I always use Solder on ends followed by heatshrink, I have learned from other peoples mistakes and learned that corrosion stars as soon as the wire is exposed to air so the way to slow the process down is to keep it sealed from moisture.
Here is an interesting fact, automotive wiring was only designed to last for 10 years.
Even if a wire looks good on the outside that doesn't mean it is not corroded on the inside.
I always use high quality 0-gauge battery cables, and install more grounds than is needed.
