the old ones fit perfectly , but was the only wheel Left hand threadThe studs are probably 1/2”. That means there’s no way to center the drum on the spindle with 5/8” holes in the drum. That would give you very poor braking and a quite a bit of instability in the front end. You really need to fix this setup to keep you and the bucket safe.
I have been told Mopar by several , but going to a machine shop , i have a .627 hole in the hub and have been told to go .0005 over so i need a knurl at .632 not finding that anywhere , i may have to put the Left hand studs back in but i don't want toMopars used left and right hand lug nuts. Don't know if all or some of them did.
Guy, I didn't understand your latest post.
More pictures would help.
On second look, they look like the drums are fastened to the hubs in a similar fashion to truck hubs. If you knew what they came from, studs should be available. I wouldn’t worry about using left hand studs if that’s the only holdup. Mopar used them up through the sixties, others too, but I can’t remember all. Napa or Car Quest can get many various studs, you might also try truck service shops.The hub looks like a trailer hub. How does the drum center on to the hub? Is there a shoulder machined on the back side of the hub? I would be very skeptical of that set up. Safety matters. Brakes aren't that expensive for these cars if you had or chose to update. I did on mine rather than taking a chance on questionable outdated brakes... I love going fast, but stopping is good! Lol.
Then it's 4 1/2"Mopar is 5 x4 1/2. Never saw a 4 9/32. Here is how you should measure a 5 hole wheel.
Already spent several trips to NAPA, O Rileys, Autozone going to a machine shop this week see what they have to say , they mention going a little larger and drill hub .0005 under knurlOn second look, they look like the drums are fastened to the hubs in a similar fashion to truck hubs. If you knew what they came from, studs should be available. I wouldn’t worry about using left hand studs if that’s the only holdup. Mopar used them up through the sixties, others too, but I can’t remember all. Napa or Car Quest can get many various studs, you might also try truck service shops.
