AZCOWBO
Well since it was supposed to hit 115-117 today, I opened my 65th birthday present early at 6am, while it was just 95, and guess what? It made it around the block and back without a hitch, What a thrill to finally get to drive it after 18months. I parked it back in the garage and now going over the punch list I have after driving it two miles.
Motor, Tranny, Steering, Brakes, Suspension operated fantastic. Love the ride with the torsion-bar frt. The following are notes I made after the ride:
Neigbors urged me not to try it again before 7am or my tires would be flat.
Frt. Seal Leaks - Replaced it yesterday, still leaks
Rr. Main Seal Leaks
Oil sensor Leaks
Tranny Cooler Braided Hose Leaks
Diff. Cover Seal Leaks - Did a lousy job the first two times.
Oil Pressure, Temperature, and Fuel Gauges don't work properly and ISSPRO quite making that style 20yrs. ago.
Headlight Brackets bounce to much - Must reinforce and re-polish.
Rear tires to wide for fenders - must remove or replace with narrower tires by 3/4" to be safe..
And to think, someone said, "A project is never done."
I will post video in a couple of days.
Rr. Main Seal Leaks
Oil sensor Leaks
