rooster57
Well i ment to post this a while back for you fellow cheapskates like me . I ordered some headlight looms from speedway for cheap and they were just that , But i didnt want to pay 100 clams for headlight conduit. SO this is the deal they say "can NOT be bent beyond 90 degrees" i think they ment 45 deg. Any way my way for what its worth is to remove the plasticliner from the center of the conduit and cut two 1 inch pieces from it and install the two pieces in each end this will hold the braided part in the alum fittings for each end. Then i uses THHN it has a thermol plastic coating and Wil Not be abrased by the conduit . And inside with the headlight wires i slid a piece of solid number 14 copper this allowed me to form the conduit however i wanted and it would stay where i put it . And not Rub my shineys. I hope this is usefull.
