Headlight mount
oino
On the headlight mount should I put bolt holes in just the top or the top and bottom?
What size bolt is best for mount them?
I haven't used these for a good many years but I used 1 3/8" bolt on the top and 2 on the bottom.
Mine uses this same type of headlight mount, only has two bolts on the top.
ya I was thinking just 2 on top. But I wasn't sure. I've seen some pics with bolts on top and bottom and some with just on top.
The extra bolt on the bottom helps keep vibrations down to a minimum.
Mine has one bolt through the top where the windshield support rod bolts to and two through the side. It makes a very sturdy mount. No vibration at all.
