insomniacshotrods
I have had one heck of a time with getting my t restarted after getting in the new engine. Went to crank engine slow cranking no matter what i did,redone the ground wires ,connections ect..found out the starter was cracked almost into by solenoid,got new starter and now it cranks ,no fire. Wired up the msd 6al box which i got off ebay used. Put on new pc-91 coil and a new distributor but no fire,got on web and msd says with aluminum heads they have to be grounded so did that,no fire. So i figured my box was bad so i bought a different distributor that didnt need the msd box to run ,no fire. Checked coil and found it was bad,new coil not in yet but i noticed that when i cranked it the voltage dropped to 9 volts on one side of the ignition switch and 1 volt on the side i had it wired to .. Does this mean my switch is bad also? How much voltage should i get at ignition switch while cranking? Thanks for info,bought car already wired and it was running fine before i messed with it lol..
