AZCOWBO
Here is the scoop. After driving the T for 40mi and running great, as I approached the house a mile away, I felt a dragging vibration and surging as if a brake or wheel bearing was dragging. I replaced the rear wheel bearings, but when I fired up the motor it started backfiring and toasted my new headers. Since then, I have replaced the old dual-point Mallory and coil with an MSD vacumn advanced dist and MSD Blaster-2 coil, new plug wires and plugs, rebuilt both carbs and installed smaller jets, reset the timing and fired it up BACKFIRE. When it engine warms up is lessons and it runs better, but not great. I am thinking due to the motor setting sol long the cam bearings have burned up and possibly the cam has some flat spots. HELP!
