My dual Holley 450's are rotting from the inside out! Went through both carbs when I bought the car less than a year ago as it had been sitting and they weren't happy. I ended up replacing a metering block and two float bowls because the plating or finish on them was coming off inside. Less than 1000 miles later and it plugged up again. When I tore them down the other metering block had "peeled" and none of the float bowls looked "great". There was some corrosion in all of them.
I'm assuming it's the ethanol in California gas doing it? I ran a lot of Holleys in the days before ethanol and never had these issues. Short term, I'm replacing parts and will run an ethanol treatment (like I put in my garden tools to keep them from clogging up all the time) in hopes that the carbs will stop eating themselves up. Has anyone ever been through this? Is there a cure?
Long term I guess I'm looking at replacing the carbs. My local carb guy suggested "Quick Fuels" as they don't have the same type of plating as Holleys, they have billet metering blocks, etc... The price is right ($700 a pair), but I'd been told by a trusted source prior to this that Quick Fuels were "junk". Not a lot of other options out there as I don't want to lose my polished tunnel ram and anything larger than 450's is liable to drown my little 350.
My present carbs are mechanical secondaries, but the Quick Fuels are vacuum. Not sure if that's going to be an issue...
Has anyone run a pair of Quick Fuel 450's? What's the good/bad?
Thanks in advance!
Thanks in advance!
