Here's the newest addition to my shop tools. The other day I was picking up the shop and found that my 3/8 extention was a good fit for 7/8 DOM. A little more scrounging and I found enough pieces to build this;
The tap holders are various sizes of running nuts drilled out to fit the shank of the tap. I also ground a flat on the shank for a 10/32 set screw. You simply slide the nut into a deep socket set it on the hole and turn the handle. Got a better handle in the works. It took longer for the paint to dry that to build the unit!
