homebuilt52
Hello y'all, Hey I'm from Texas, if you did'nt already know that. This is my 1st post and I'm not so good at typing (hunt&peck) I joined this site for imfo. I'm building a t-bucket, I bought the frame from Spirit Ind. A 23 track-T, I have run the brake lines from the M/C along the inside of the frame. I have a 10 bolt rear end w/brackets welded on, I have a 4" dropped tube front axle fitted for ford spindles, I got the axle kit from speedway. It was fitted for radius rods w/clevises, but I had some more brackets welded on for a "4 bar setup" I still need some brackets welded to the frame. The frame is fitted for a chevy 350/350trans. I got a 350 motor, which I'll need to rebuild, The project is coming along slowly, but I want it done right! I'm sure I will find alot of imfo on this site with all of the T-bucket "freaks" out there. sorry for the long post, I'll be around...Scott.
