How to Obtain a California VIN #
johnstacy
How to Register a Smog Exempt Hot Rod in California
First off don’t believe anything anyone says about their terrible registration ordeal it is possible to register smog exempt with the correct information and paperwork In California. There is a little known law that allows 500 vehicles every year to be registered smog exempt and use any year motor in the vehicle. Every year starting January 1st California allows 500 vehicles to be registered smog exempt if you have requested from the DMV a S.B. #100. If you call the Bureau of Automotive Repairs at 916-657-6560 and ask them if there is any special construction SB 100 numbers left for the year, if they say yes you’re in good shape. They won’t tell you how many numbers are left for the year just if there are some still available
This is where the work starts you’ll need the following forms
1. Form #124 Applications for Assigned Vehicle Identification Number
2. Form #343 Applications for Title Or Registration
3. Form # 5036 Statement of Construction
4. Form #256 Statements of Facts
Fill out all forms then go to DMV with forms and receipts where you purchased everything for the car tell them you want to register this car as a special construction vehicle and you need them to call Sacramento at this number 916-657-6560 and request a Special Construction SB 100 number’ they’ll probably tell you there are no more SB 100 left for the year but you’ll know that’s not true you have already confirmed there are numbers left. Let them know you have contacted The Bureau of Automotive Repairs and confirmed numbers are still remaining. This will take a while for them to call be patient they probably have never done this.
After you pay the DMV some money based on the receipts given to them for the cost of vehicle parts they will give you a SB100 Number that’s your ticket to a Smog Exempt Vehicle. They will tell you what S.B 100 number you have but you will receive official notice from the DMV in about 2 weeks via U.S. Mail. With this SB 100 you will be able to choose the year model you want to register your vehicle as.
Now call your local Highway Patrol office and ask for an appointment for assigned vin number. My car wasn’t completed it wasn’t even wired to run yet the CHP did not care, let them know how far you are in your construction. At that point they attached a vin number to my vehicle
When finished with CHP and you have a vin number. Next is Bureau of Automotive Repair Referee Station. He’ll need your car for a visual inspection checking only for a PCV to carburetor valve and positive ventilation from a valve cover to the air cleaner, my car was never started up at this check. When you pass the Bureau of automotive repair the last check is lights and brakes at an official inspection station
Each place you visit will give you paperwork take all this back to the DMV and get Happy.
I just went thru the process it wasn't that hard,it did take some time because i didn't know what i was doing when i started i hope this helps others.
