hubs for 1930 axle
georgedombeck
Anyone know what hubs will go on 30 chev spindles? I tried speedway, they dont make anything for old stuff. That was a quote. thanks, george
there are kits out there to put disc brakes on the 28 to 46 chevy . we just picked up a 34 pu for a c note and have located an old haywagon made from a 30's chevy chassis. the site i loked at used camero type parts and said 6 bolt hubs are availabe One guy used 4 x 4 nissan rotors and the orig 6 bolt hubs and home make caliper brackets.
Just curious why '30 Chevy spindles??
The eci kit has "spindle spacers" what ever they are, to mount up mid 70's camaro discs. Does anyone know if the "Spacers" just move the rotor/hub out, or is it to change the diameter of the spindle? thanks, george
Probably dose both. I would check the kingpin dia. to see if you could use the '49 to '54 chevy spindles and brakes.
