Gents,
I have a serious problem with this setup. I have a Total performance 23T sucide front end with the short shocks.I have measured and re-measured my radius rod measurements, checked to make sure that the caster angle is at 5-degrees positive based on Total's build instructions.I've even cut off the bolt and ground it down to clear the shocks. But no matter what I do, one side of the mounting brackets are biting into my shocks. There is lot of clearance between the shocks and the bracker towards the front of the car, but none towards the back.
I will try to post a couple of pics tomorrow. Can you please gimme some tips on how this problem can be fixed?
Much thanks!
-Andy
