Jag XJ wheel bolt pattern
gfigms
Is the XJ IRS bolt pattern a ford or chevy pattern? I currently have a Currie Ford 9" rear end with the ford pattern and need to know if I can find hubs for the XJ rear end to match ford 4.5 or am I going to have to buy new rims if it is a chevy pattern ... make sense?
Can the hubs be "redrilled" to a ford pattern or are "ford type hubs" available for a XJ rear end? ... new rims will cost over $500 and then I'll have the old rims that no one, more than likely, will want.
If you run a search you will find that GAB recently posted info for a small fixture to redrill bolt patterns. one of them is for a Jag........ruggs
