cooter
You mean corvairWe not running a vega. Im running a flaming river
YaYou mean corvair
Have you guys had that block hot tanked and magnafluxed?
I remember reading this thread from the beginning a while back, but my recollection fails me on the block prep.
There's a lot of what looks to be serious corrosion in the threads in that first pic, which usually means some one ran water without antifreeze, usually a cost cutting work around when there's a water leak requiring regular refills . . .
The stain lines are not exactly encouraging either, although they could be benign.
If it were my block, and I do have a 305 on a stand as I speak, I'd chase all those threads and do a very careful visual inspection for corrosion damaged threads, which won't seal correctly when you put in the head bolts, no matter how much sealer you put on them.
Now is the time to be sure that you're building your motor on a solid foundation. . . . Nothing is more depressing than seeing steam in the exhaust or water in the oil after a labor intensive rebuild.
Darlene
Nothin wrong with a budget refresh as long as it’s within reasonable tolerance... will it run as good or long as a “correct” rebuild? No! But what do you need? As long as the cylinders are round and not tapered.... file fit the rings, use cast rings, check em top and botom of the bores. It’s a good learning experience! I was back yard rebuilding motors for go carts, dirt bikes, etc when I was real young... and not the “correct way” I learned a lot. Nice to see young people with interest in mechanical things.Yeah, still gotta chase threads in block.
I did a lot of VWs and Corvairs back in the day and have been known to cut and overlap head gasket/seal rings when didn't have no money. Never had a failure.We grew up poor. Use to build v.w. engines and the cylinders we're all different sizes. Parts were out of our budget so we improvise. We just gotta play with what we got. Makes us appreciate it when we get the good stuff.
We’re all poor compared to somebody, lol... funny, I’ve had well off people tell me how much they envy my abilities to do various different things... I tell them to be careful what they wish for, there was a price paid for that knowledge....When you're poor, any way is better than no way. Just git 'er done. BTDT I was once poor--Oh I still am!![]()
Hi Jarrett , did you get any more goodies ?
