I discovered a crack in the main leaf of the buggy rear spring on my roadster. The spring is probably an old Ford spring. It has 4 leaves with tapered ends. I disassembled it last year and had some arc put back in it, probably the source of the crack. The problem arises from trying to decide what to do. The spring perches measure 40.5 inches wide. The shackles are 2.5 inches. I don't mind replacing the whole spring, but do not want to pay for a custom length. I think I can fudge half an inch on the length and could use different length shackles to find a replacement. I know there are a couple of other measurements involved in getting the correct spring. I have googled and checked Posies, Speedway and all the catalogs I have, but have been unable to find something that seems to be the right replacement. I hope to do this for less than $250 and if I pay that I would not expect to have to modify anything. I do not want to add coilovers or change the perches. I need some advise or recommendations to get me going. It is not the high arch type.
