LumenAl
Three years ago when I was getting ready for the 2007 roadster show, the pinstripe was scheduled to come over, I had everything done, but he wanted casters on the body stand I had made... so I bought some casters, made legs that would quickly attach to the body stand so I just needed a couple of guys to come over, lift it while I screwed them in... So 9:00 PM the night before the pinstripe is to show, they show up to lift it... within 3 seconds, the rear deck-lid hit the ground... So I started a quick and dirty repair job... ground down the crack, Bondo, sand, primer, seal, shoot color and covered with clear before I wet-sanded to get ready for him to pinstripe that next morning... time you ask? 4:30 in the morning it's done, then I left for Portland.
So what happened was, after 3 years, my quick and dirty repair job cracked as you can see in the photo just to the right of the center section.
So ground it down, laid two layers of glass for strength...
did a little more grinding then applied and shaped the center section with Duraglass... that stuff is tough as my ex!
then I applied several coats of bondo and Metal glaze to get it ready to prime...
shot primer on 4 different occasions... sanding and sanding to get the right shape...
Shot sealer
then onto 4 coats of color and 4 coats of clear as you see here
Tomorrow I wet-sand, get the pinstripe back Saturday, then shoot 4 more coats of clear, wet-sand, then 3 stage polish... think we are going to made it to the show with one day left!
	Shot sealer
