"The Bat" out of hell
How low a pan can be found? for low motor sbc
lowist I found so far was 8.25 #30900
My slamguard has done its job on several occasions (3-1/2" clearance)...
Great point about the plug!NOTE!!! Drain plug is on the wrong side, just lucky it did not loosen and work it's way off, seen that happen way too many times, I move it to the other side or to the rear of the pan... Engines need to be mounted higher in the frame. Get over trying to make a flat floor...
Could anyone tell me what the depth of the trans sump (say a 350) is and what the depth of the flywheel/with cover is in relation to these stock(?) oil pans? I would think that crunching the flywheel would be worse. Also, IIRC a trans with deep sump will hang lower than the engine pan will. No? Correct me if I am wrong.
John
Or does the oil pan run block for the flywheel cover?
