Ted Brown
I can;t find where I was reading about someone saying that because a U joint had grease holes in it, that it was weaker, I would say to the opposite... If you have a stock axle and are having breakage problems, you can gain a lot-O-strength by having that axle center drilled, to a 22 Cal. hole... as this is now a TUBE axle, and has gained another wall to break, making it mucho stronger, same goes for any solid parts, say you can only use or have room for a bracket that needs to be stronger than the 1/4" you have room for?? make it from two pieces of 1/8" welded together, now it is stronger than a one piece of 1/4" material, as to bend it now, one piece has the stretch and the other has to compress, so to speak, I think you get the point, SWC 40 Willys used to run stock Olds axles for many years, center drilling will prolong axle life... just remember to drill and tap the outer end of the hole and install a pipe plug in the hole. hehe keeps the oil in rear end Just a thought for new guys starting their builds...
