I found a set of model A springs last week. The rear spring is a high arch. Over the weekend we mocked the frame and rear axle together with the rear spring. That spring puts the backend of the car way up in the air (not surprising being a high arch, eh). The plans I am using has the spring perch centered on the axle shaft. Does the spring perch have to be centered on the axle or can I drop the mount to get a lower ride height? The way it is currently set up I have about 5 degrees foward rake. I don't want to lower it very much (maybe 2 inches), mainly want to level the car and not make it look like a Rat Roth cartoon. My son says to bigger front tires on it.
Adrian
Adrian
